Process Content Creation (By Data Set ID) (JSON)
Submits a request to initiate a new Content Creation (Email) operation.
Request takes a JSON Email Parameters (with Runtime Parameters) object or a JSON Parameters object describing a list of runtime parameters., and on success returns a response containing additional headers that specify the ID of the new operation as well as link URLs that can be used to retrieve further information/cancel the operation.
Request
Method Type: |
POST |
URI: |
/rest/serverengine/workflow/contentcreation/email/{templateId}/{dataSetId} |
Content: | A JSON Email Parameters (with Runtime Parameters) object, or a JSON Parameters object describing a list of runtime parameters. |
Content Type: |
application/json |
Add. Headers: |
Parameters
Path
templateId |
dataSetId |
The Data Set ID which was the result of a data mapping operation. |
Query
section |
Default section in template |
The section of the Email context to export. |
Response
Success
202 Accepted |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
404 Not Found |
application/json |
