Get Template Resource
Submits a request to retrieve a resource from a template stored in the File Store.
Request takes no content, and on success returns a response containing the resource from the template.
Request
Method Type: |
GET |
URI: |
/rest/serverengine/workflow/contentcreation/html/{templateId}/{relPath: .+} |
Content: | – |
Content Type: |
Add. Headers: |
Parameters
Path
templateId |
The Managed File ID (or Name) of the template in File Store |
relPath |
The relative path to the resource within the template |
Response
Success
200 OK |
Resource located at the relative path within template | (Depends on Resource requested) | – | Resource successfully retrieved |
Error
400 |
application/json |
Unable to open resource within template or resource doesn’t exist |
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
404 Not Found |
application/json |
Template not found in File Store |
500 |
application/json |
Unable to open template or template doesn’t exist |
