Process Content Creation (By Data) (JSON)
Submits a request to create new HTML content for the Web context.
Request takes a JSON Record Data List of the data values for the Data Record as content, and on success returns a response containing the HTML output produced, specific to the record data and parameters specified.
Request
Method Type:
POST
URI:
/rest/serverengine/workflow/contentcreation/html/{templateId}
Content: JSON Record Data List specifying a list of data values for the Data Record
Content Type:
application/json
Add. Headers:
Parameters
Path
templateId
The Managed File ID (or Name) of the template in File Store
Query
section
Default section in template
The section within the Web context to create
inline
NONE
The inline mode to be used in the creation of content. Possible values:
  • NONE - no inlining
  • CSS - converts style rules to inline styles on elements
  • ALL - inline all resources
  • LOCAL - inline local resources; remote resources remain external
cssSelector
No
String
A CSS selector for the creation of only a specific HTML element within the template
Response
Success
200
OK
The entire HTML output for the Data Record, or the inner HTML of the first element that matches the given CSS selector, or an empty string if the CSS selector produced no results text/html – Output created successfully
Error
400
Bad Request
application/json
Web context not found / Web section not found
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
404 Not Found
application/json
Template not found in File Store/Server
500
Internal Server Error
application/json
Content Creation Error: Web context in template not found / Invalid CSS selector.
