Process Content Creation (No Data)
Submits a request to create new HTML content for the Web context.
Request takes no content, and on success returns a response containing the HTML output produced, using only the template, no input data and specific to the parameters specified.
Request
Method Type: |
POST |
URI: |
/rest/serverengine/workflow/contentcreation/html/{templateId} |
Content: | – |
Content Type: |
Add. Headers: |
Parameters
Path
templateId |
The Managed File ID (or Name) of the template in File Store |
Query
section |
Default section in template |
The section within the Web context to create |
inline |
NONE |
The inline mode to be used in the creation of content. Possible values:
cssSelector |
No |
A CSS selector for the creation of only a specific HTML element within the template |
Response
Success
200 OK |
The entire HTML output for the Data Record, or the inner HTML of the first element that matches the given CSS selector, or an empty string if the CSS selector produced no results | text/html | – | Output created successfully |
Error
400 |
application/json |
Web context not found / Web section not found |
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
404 Not Found |
application/json |
Template not found in File Store |
500 |
application/json |
Content Creation Error: Web context in template not found / Invalid CSS selector. |
