Create Preview Image (By Data) (JSON)
Submits a request to create a preview image of the print, email, or web output for a single data record.
Request takes a JSON Record Data List (with Image Parameters) of the data values for the Data Record as content, and on success returns a response containing the image output produced, specific to the record data and parameters specified.
Request
Method Type:
POST
URI:
/rest/serverengine/workflow/contentcreation/imagepreview/{templateId}
Content: JSON Record Data List (with Image Parameters) of the data values for the Data Record
Content Type:
application/json
Add. Headers:
Parameters
Path Parameters
templateId
Yes
String
The Managed File ID (or Name) of the template in File Store
Response
Success
200
OK
Preview Image
image/jpeg
Creation of a preview image successful.
Response when the image parameters specified contain:
  • a type value of JPG or JPEG
  • an archive value and pages value that would result in a single page
200
OK
Preview Image
image/png
  • a type value of PNG
200
OK
Preview Images (Zipped)
application/zip
Creation of preview images successful.
  • an archive value and pages value that would result in a multiple pages
Error
400
Bad Request
application/json
Context not found / Section not found
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
404 Not Found
application/json
Template not found in File Store
