Create Preview Image (By Data Record) (JSON)
Submits a request to create a preview image of the print, email, or web
Request takes a set of JSON Image Parameters as content, and on success returns a response containing the image output produced, specific to the record data and parameters specified.
Request
Method Type: |
POST |
URI: | |
Content: | JSON Image Parameters specifying parameters to be used for content creation |
Content Type: |
application/json |
Add. Headers: |
Parameters
Query Parameters
The following lists the query parameters accepted by this method:
templateId |
Yes |
String |
The Managed File ID (or Name) of the template in File Store |
dataRecordId |
Yes |
Number |
The ID of the Data Record entity in Server |
Response
Success
200 OK |
Preview Image |
image/jpeg |
Creation of a preview image successful. Response when the image parameters specified contain:
200 OK |
Preview Image |
image/png |
200 OK |
Preview Images (Zipped) |
application/zip |
Creation of preview images successful. Response when the image parameters specified contain:
Error
400 |
application/json |
Context not found / Section not found |
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
404 Not Found |
application/json |
Template or Data Record entity not found in File Store/Server |
