Create Preview PDF (By Data)
Submits a request to create a preview PDF of the print output for a single data record.
Request takes binary file data as content, and on success returns a response containing the Managed File ID for the newly created preview PDF file.
Request
Method Type:
POST
URI:
/rest/serverengine/workflow/contentcreation/pdfpreview/{templateId}/{dmConfigId}
Content: Data File (File)
Content Type:
application/octet-stream
Add. Headers:
Parameters
Path
templateId
The Managed File ID (or Name) of the template in File Store
dmConfigId
The Managed File ID (or Name) of the Data Mapping configuration in File Store
Query
persist
true
Whether the Data Record produced will be persisted in Server
Response
Success
200
OK
Managed File ID text/plain Creation of preview PDF in File Store successful
Error
400
Bad Request
application/json
Unable to open resource within template or resource doesn’t exist / Context not found / Section not found
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
404 Not Found
application/json
Template, Data Mapping configuration or Data Record entity not found in File Store/Server
