Create Preview PDF (By Data Record)
Submits a request to create a preview PDF of the print output for a single data record.
Request takes no content, and on success returns a response containing the Managed File ID for the newly created preview PDF file.
Request
Method Type: |
GET |
URI: |
/rest/serverengine/workflow/contentcreation/pdfpreviewdirect |
Content: | – |
Content Type: |
Add. Headers: |
Query
templateId |
The Managed File ID (or Name) of the template in File Store |
dataRecordId |
The ID of the Data Record entity in Server |
Response
Success
200 OK |
Managed File ID | text/plain | – | Creation of preview PDF in File Store successful |
Error
400 |
application/json |
Unable to open resource within template or resource doesn’t exist / Context not found / Section not found |
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
404 Not Found |
application/json |
Template or Data Record entity not found in File Store/Server |
