Get All Operations
Returns a list of all the workflow operations actively running on the Server.
Request takes no content, and on success returns a response containing a JSON Operations List of all the actively running operations.
Request
Method Type:
GET
URI:
/rest/serverengine/workflow/contentcreation/getOperations
Content: –
Content Type:
Add. Headers:
Response
Success
200
OK
JSON Operations List of all the actively running operations in Server application/json – List of actively running operations successfully retrieved
Error
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
