Get Progress of Operation
Retrieves the progress of a running Content Creation operation of a specific operation ID.
Request takes no content, and on success returns a response containing the current value of operation progress (values ranging from 0 – 100, followed by the value of 'done' on completion).
Request
Method Type: |
GET |
URI: |
/rest/serverengine/workflow/contentcreation/getProgress/{operationId} |
Content: | – |
Content Type: |
Add. Headers: |
Parameters
Path
operationId |
Operation ID of Content Creation operation |
Response
Success
200 OK |
Progress value of Content Creation operation | text/plain | – | Progress of operation successfully retrieved |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
