Process Content Creation (By Data Record) (JSON)
Submits a request to initiate a new Content Creation operation.
Request takes a JSON Identifier List (with Runtime Parameters) of Data Record IDs as content, and on success returns a response containing additional headers that specify the ID of the new operation as well as link URLs that can be used to retrieve further information/cancel the operation.
Request
Method Type: |
POST |
URI: | |
Content: | JSON Identifier List (with Runtime Parameters) specifying a list of Data Record entity IDs |
Content Type: |
application/json |
Add. Headers: |
Parameters
Path
templateId |
The Managed File ID (or Name) of the template in File Store |
Response
Success
202 Accepted |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
404 Not Found |
application/json |
Template not found in File Store |
