Update Content Item Properties
Submits a request to update (and replace) the properties for a specific Content Item entity in the Server.
Request takes a JSON Name/Value List as content (the Content Item ID and the new properties), and on success returns a response containing the result of the request for update/replacement (“true”).
Request
Method Type: |
PUT |
URI: |
/rest/serverengine/entity/contentitems/{contentItemId}/properties |
Content: | JSON Name/Value List of properties for Content Item |
Content Type: |
application/json |
Add. Headers: |
Parameters
Path
contentItemId |
ID of the Content Item entity in Server |
Response
Success
200 OK |
Result of request to update Content Item | text/plain | – | Update of Content Item properties successfully requested (response of “true” for success) |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
500 |
application/json |
Server error or Content Item ID mismatch in JSON |
