Update Content Set Properties
Submits a request to update (and replace) the properties for a specific Content Set entity in the Server.
Request takes a JSON Name/Value List as content (the Content Set ID and the new properties), and on success returns a response containing the result of the request for update/replacement (“true”).
Request
Method Type: |
PUT |
URI: |
/rest/serverengine/entity/contentsets/{contentSetId}/properties |
Content: | JSON Name/Value List of properties for Content Set |
Content Type: |
application/json |
Add. Headers: |
Parameters
Path
contentSetId |
ID of the Content Set entity in Server |
Response
Success
200 OK |
Result of request to update Content Set | text/plain | – | Update of Content Set properties successfully requested (response of “true” for success) |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
500 |
application/json |
Server error or Content Set ID mismatch in JSON |
