Get Result of Operation
Retrieves the final result of a completed Data Mapping operation of a specific operation ID.
Request takes no content, and on success returns a response containing the ID of the Data Set produced (or Content Set for a PDF/VT to Content Set specific data mapping operation).
Alternatively, if the operation was to only validate the data mapping, then a response containing a JSON Data Mapping Validation Result will be returned instead.
Request
Method Type:
POST
URI:
/rest/serverengine/workflow/datamining/getResult/{operationId}
Content:
Content Type:
Add. Headers:
Parameters
Path
operationId
Operation ID of Data Mapping operation
Response
Success
200
OK
Data Set ID (or Content Set ID)
text/plain Result of completed operation successfully retrieved
Success (validate)
200
OK
Error
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
404 Not Found
application/json
Operation not found in Server
