Process Data Mapping
Submits a request to initiate a new Data Mapping operation.
Request takes an optional JSON Data Mapping Parameters, and on success returns a response containing additional headers that specify the ID of the new operation as well as link URLs that can be used to retrieve further information/cancel the operation.
Request
Method Type:
POST
URI:
/rest/serverengine/workflow/datamining/{configId}/{dataFileId}
Content:
(Optional) JSON Data Mapping Parameters
Content Type:
application/json
Add. Headers:
Parameters
Path
configId
The Managed File ID (or Name) of the Data Mapping configuration in File Store
dataFileId – – –
The Managed File ID (or Name) of the PDF/VT data file in File Store
Query
validate – –
false
Only validate the Data Mapping operation to check for mapping errors
Response
Success
202
Accepted
  • operationId – Operation ID of new Data Mapping operation
Error
400
Bad Request
application/json –
Data file or Data Mapping Configuration not found in File Store
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
Error (Validate)
401 Unauthorized
application/json
403 Forbidden
application/json
500
Internal Server Error
application/json –
