Process Data Mapping (JSON)
Submits a request to initiate a new Data Mapping operation.
Request takes a JSON Identifier (for Data Mapping) as content, and on success returns a response containing additional headers that specify the ID of the new operation as well as link URLs that can be used to retrieve further information/cancel the operation.
Request
Method Type: |
POST |
URI: | |
Content: | JSON Identifier (for Data Mapping) |
Content Type: |
application/json |
Add. Headers: |
Parameters
Path
configId | – | – | – |
Managed File ID (or Name) of the Data Mapping configuration in File Store |
Query
validate | – | – |
false |
Only validate the Data Mapping operation to check for mapping errors |
Response
Success
202 Accepted |
Error
400 |
application/json | – |
Data file or Data Mapping Configuration not found in File Store |
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
500 |
JSON Identifier bad or missing Data file or Data Mapping Configuration not found in File Store |
