Process Data Mapping (PDF/VT to Data Set)
Submits a request to initiate a new Data Mapping operation using a PDF/VT data file specifically.
No Data Mapping configuration is specified, and a Data Set will be created based on the default properties extracted from the metadata of the PDF/VT data file.
Request takes no content, and on success returns a response containing additional headers that specify the ID of the new operation as well as link URLs that can be used to retrieve further information/cancel the operation.
Request
Method Type: |
POST |
URI: | |
Content: | – |
Content Type: |
Add. Headers: |
Parameters
Path
dataFileId | – | – | – |
The Managed File ID (or Name) of the PDF/VT data file in File Store |
Response
Success
202 Accepted |
Error
400 |
application/json | – |
PDF/VT data file not found in File Store |
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
