Add Data Records
Submits a request to add one or more Data Record entities to one or more entities in the Server as either:
- a Data Record of an existing Data Set entity in the Server, or
- a nested Data Record in a Data Table of an existing Data Record entity in the Server
Request takes JSON New Record Lists as content (each with the Data Set/Data Record ID, Data Table and the new records/values), and on success returns a response containing no content.
Request
Method Type: |
POST |
URI: | |
Content: | JSON New Record Lists of the new Data Records |
Content Type: |
application/json |
Add. Headers: |
Response
Success
200 OK |
– | – | – | Data Records for Data Set/Data Record entities successfully added |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
500 |
application/json |
JSON New Record Lists invalid or missing required structure |
