Get Data Record Values
Returns a list of the values for a specific Data Record entity, and potentially the values of any nested Data Records (if recursive).
Request takes no content, and on success returns a response containing either:
Request
Method Type:
GET
URI:
/rest/serverengine/entity/datarecords/{dataRecordId}/values
Content:
Content Type:
Add. Headers:
Parameters
Path
dataRecordId
ID of the Data Record entity in Server
Query
recursive
False
Recurse all Data Tables within the Data Record and retrieve the values of any nested Data Records
explicitTypes
False
Deprecated
Retrieve both values and data types of the Data Record
outputFormat
default
The output format of the data (either default, explicitTypes or simplified).
Note: Query parameters are case-sensitive.
Response
Success
200
OK
JSON Record Content List of the values for Data Record application/json Data Record entity values successfully retrieved
200
OK
JSON Record Content List (Explicit Types) of the values and data types for Data Record application/json Data Record entity values and data types successfully retrieved
Error
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
500
Internal Server Error
application/json
Server error or invalid Data Record ID specified
