Get Multiple Data Record Values (JSON)
Returns a list of the values for one or more Data Record entities, and potentially the values of any nested Data Records (if recursive).
Request takes a JSON Data Record Identifier List (with Parameters) of the Data Record IDs as content, and on success returns a response, depending on the specified output format, containing either:
Request
Method Type:
POST
URI:
/rest/serverengine/entity/datarecords/values
Content: JSON Data Record Identifier List (with Parameters) specifying the Data Record entity IDs
Content Type:
application/json
Add. Headers:
Response
Success
200
OK
JSON Record Content Lists of the values for each Data Record application/json Data Record entity values successfully retrieved
200
OK
JSON Record Content Lists (Explicit Types) of the values and data types for each Data Record application/json Data Record entity values and data types successfully retrieved
200
OK
JSON Record Content Lists (simplified) of the values for each Data Record application/json   Data Record entity values successfully retrieved
Error
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
500
Internal Server Error
application/json
Server error or invalid Data Record ID specified
