Update Data Record Values
Submits a request to update one or more values for a specific Data Record entity in the Server.
Request takes a JSON Record Content List (Fields Only) as content (the Data Record ID and the new values), and on success returns a response containing no content.
Request
Method Type: |
PUT |
URI: | |
Content: | JSON Record Content List (Fields Only) of the values for Data Record |
Content Type: |
application/json |
Add. Headers: |
Parameters
Path
dataRecordId |
ID of the Data Record entity in Server |
Response
Success
200 OK |
– | – | – | Data Record entity values successfully updated |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
500 |
application/json |
Server error or Data Record ID mismatch in JSON |
