Update Multiple Data Record Properties
Submits a request to update one or more properties for one or more Data Record entities in the Server.
Request takes JSON Name/Value Lists as content (each with the Data Record ID and the new properties), and on success returns a response containing no content.
Request
Method Type: |
PUT |
URI: | |
Content: | JSON Name/Value Lists of the properties of the Data Records |
Content Type: |
application/json |
Add. Headers: |
Response
Success
200 OK |
– | – | – | Properties of Data Record entities successfully updated |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
