Update Data Set Properties
Submits a request to update (and replace) the properties for a specific Data Set entity in the Server.
Request takes a JSON Name/Value List as content (the Data Set ID and the new properties), and on success returns a response containing the result of the request for update/replacement (“true”).
Request
Method Type: |
PUT |
URI: | |
Content: | JSON Name/Value List of properties for Data Set |
Content Type: |
application/json |
Add. Headers: |
Parameters
Path
dataSetId |
ID of the Data Set entity in Server |
Response
Success
200 OK |
Result of request to update Data Set | text/plain | – | Update of Data Set properties successfully requested (response of “true” for success) |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
500 |
application/json |
Server error or Data Set ID mismatch in JSON |
