Get Document Set Metadata Properties
Returns a list of the metadata properties for a specific Document Set entity.
Request takes no content, and on success returns a response containing a JSON Name/Value List (Properties Only) of all the metadata properties for the Document Set.
Request
Method Type: |
GET |
URI: |
/rest/serverengine/entity/documentsets/{documentSetId}/metadata |
Content: | – |
Content Type: |
Add. Headers: |
Parameters
Path
documentSetId |
The ID of the Document Set entity in Server |
Response
Success
200 OK |
JSON Name/Value List (Properties Only) of metadata properties for Document Set | application/json | – | Document Set entity metadata properties successfully retrieved |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
