Get Documents for Document Set
Returns a list of all the Document entities contained within a specific Document Set entity.
Request takes no content, and on success returns a response containing a JSON Identifier List of all the Documents in the Document Set.
Request
Method Type:
GET
URI:
/rest/serverengine/entity/documentsets/{documentSetId}
Content:
Content Type:
Add. Headers:
Parameters
Path
documentSetId
The ID of the Document Set entity in Server
Response
Success
200
OK
JSON Identifier List of all the Documents in Document Set application/json Identifier List of Documents returned
Error
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
