Delete Managed File or Directory
Removes an existing file or directory of a specific Managed File ID (or Name) from the File Store.
Request takes no content, and on success returns a response containing the result of the request for removal.
Request
Method Type: |
GET |
URI: | |
Content: | – |
Content Type: |
Add. Headers: |
Parameters
Path
fileId |
The Managed File ID (or Name) of the file or directory in File Store |
Response
Success
200 OK |
Result of request for removal | text/plain | – | Removal of file or directory successfully requested from File Store |
Error
400 |
application/json |
Deletion failed / File still required by OL Connect |
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
404 |
application/json |
Invalid Managed File ID |
500 Internal Server Error |
application/json |
Connection refused |
