Synchronize/Upload Managed Directory (Internal Only)
Synchronizes/uploads an existing directory of a specific Managed File ID (or Name) from a Server Extension File Store, to the Server's File Store and is used exclusively in a clustered environment.
Request takes zipped file data as content, and on success returns a response containing the Managed File ID (or Name) of the directory.
Method Type: |
POST |
URI: | |
Content: | Directory (as zipped file) |
Content Type: |
application/octet-stream |
Add. Headers: |
Parameters
Path
fileId |
The Managed File ID (or Name) of the file or directory in File Store |
Response
Success
200 OK |
Managed File ID (or Name) | text/plain | – | Directory successfully synchronized/uploaded to File Store |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
405 Not Allowed |
application/json |
Directory already exists in File Store |
