Upload Data Mapping Configuration
Submits a Data Mapping configuration to the File Store.
Request takes binary file data as content, and on success returns a response containing the new Managed File ID for the configuration.
Request
Method Type: |
POST |
URI: | |
Content: | Data Mapping Configuration (File) |
Content Type: |
application/octet-stream |
Add. Headers: |
Parameters
Query
filename | – | – | – |
The file name of the configuration to be uploaded |
persistent |
false |
Whether the configuration to be uploaded will be persistent in File Store |
Response
Success
200 OK |
Managed File ID (or Name) | text/plain | – | Configuration successfully uploaded to File Store |
Error
400 |
application/json |
Request contains no data for upload to File Store. |
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
