Process Job Creation (By Content Set) (JSON)
Submits a request to initiate a new Job Creation operation.
Request takes a JSON Identifier List of Content Set IDs as content, and on success returns a response containing additional headers that specify the ID of the new operation as well as link URLs that can be used to retrieve further information/cancel the operation.
Request
Method Type:
POST
URI:
/rest/serverengine/workflow/jobcreation/{configId}
Content: JSON Identifier List specifying a list of Content Set entity IDs
Content Type:
application/json
Add. Headers:
Parameters
Path Parameters
configId
The Managed File ID (or Name) of the Job Creation Preset in File Store
Response
Success
202
Accepted
  • operationId – Operation ID of new Job Creation operation
Error
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
404 Not Found
application/json
Job Creation Preset or Content Set entity not found in File Store/Server
