Process Job Creation (By Job Set Structure) (JSON)
Submits a request to initiate a new Job Creation operation.
Request takes a JSON Job Set Structure containing a list of Content Items as content, and on success returns a response containing additional headers that specify the ID of the new operation as well as link URLs that can be used to retrieve further information/cancel the operation.
Request
Method Type: |
POST |
URI: | |
Content: | JSON Job Set Structure describing Job Set (and Content Items) |
Content Type: |
application/json |
Add. Headers: |
Response
Success
202 Accepted |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
