Update Job Properties
Submits a request to update (and replace) the properties for a specific Job entity in the Server.
Request takes a JSON Name/Value List as content (the Job ID and the new properties), and on success returns a response containing the result of the request for update/replacement (“true”).
Request
Method Type:
PUT
URI:
/rest/serverengine/entity/jobs/{jobId}/properties
Content: JSON Name/Value List of properties for Job
Content Type:
application/json
Add. Headers:
Parameters
Path
jobId
The ID of the Job entity in Server
Response
Success
200
OK
Result of request to update Job text/plain – Update of Job properties successfully requested (response of “true” for success)
Error
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
500
Internal Server Error
application/json
Server error or Job ID mismatch in JSON
