Get Document Sets for Job Segment
Returns a list of all the Document Set entities contained within a specific Job Segment entity.
Request takes no content, and on success returns a response containing a JSON Identifier List of all the Document Sets in the Job Segment.
Request
Method Type: |
GET |
URI: | |
Content: | – |
Content Type: |
Add. Headers: |
Parameters
Path
jobSegmentId |
The ID of the Job Segment entity in Server |
Response
Success
200 OK |
JSON Identifier List of all the Document Sets in Job Segment | application/json | – | Identifier List of Document Sets returned |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
