Get Job Set Properties
Returns a list of the properties for a specific Job Set entity.
Request takes no content, and on success returns a response containing a JSON Name/Value List (Properties Only) of all the properties for the Job Set.
Request
Method Type:
GET
URI:
/rest/serverengine/entity/jobsets/{jobSetId}/properties
Content:
Content Type:
Add. Headers:
Parameters
Path
jobSetId
The ID of the Job Set entity in Server
Response
Success
200
OK
JSON Name/Value List (Properties Only) of properties for Job Set application/json Job Set entity properties successfully retrieved
Error
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
