Finding all the Content Sets in the Server
Problem
You want to obtain a list of all the previously created Content Sets contained in the OL Connect Server potentially for use in a Job Creation operation.
Solution
The solution is to create a request using the following URI and method type and submit it to the server via the Content Set Entity REST service:
Get All Content Sets /rest/serverengine/entity/contentsets GET
Example
HTML5
cse-get-all-contentsets.html
Copy
<!DOCTYPE html>
<html>
    <head>
        <meta charset="utf-8">
        <title>Get All Content Sets Example</title>
        <script src="js/cse-get-all-contentsets.js"></script>
    </head>
    <body>
        <h2>Content Set Entity Service - Get All Content Sets Example</h2>
        <form>
            <fieldset>
                <legend>Options</legend>
                <div>
                    <label for="type">Entity Type:</label>
                    <select id="type">
                        <option value="default">Default</option>
                        <option value="print">Print</option>
                        <option value="email">Email</option>
                    </select>
                </div>
            </fieldset>
            <fieldset>
                <legend>Actions</legend>
                <div>
                </div>
            </fieldset>
        </form>
    </body>
</html>
JavaScript/jQuery
Copy
/* Content Set Entity Service - Get All Content Sets Example */
(function ($, c) {
    "use strict";
    $(function () {
        c.setupExample();
            event.preventDefault();
            var type = $("#type").val();
            var settings = {
                type:   "GET",
                url:    "/rest/serverengine/entity/contentsets"
            if (type !== "default") settings.data = { type: type };
            $.ajax(settings)
                .done(function (response) {
                    c.displayHeading("Content Set IDs");
                    c.displaySubResult("Plain", c.jsonIDListToPlain(response));
                    c.displaySubResult("JSON Identifier List", c.jsonPrettyPrint(response));
}(jQuery, Common));
Screenshot & Output
Usage
To run the example simply select the Submit button to request a list of the all the content sets currently contained within the server.
The resulting list will then be returned and displayed to the Results area in both Plain list and JSON Identifier List formats.
Further Reading
See the Content Set Entity Service page of the REST API Reference section for further detail.
