Uploading a Template to the File Store
Problem
You want to upload a template to the File Store so that it can be used as part of a Content Creation operation.
Solution
The solution is to create a request using the following URI and method type to submit the template to the server via the File Store REST service:
Upload Template | /rest/serverengine/filestore/template | POST |
Example
HTML5
fs-template-upload.html
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<title>Upload Template Example</title>
<script src="js/fs-template-upload.js"></script>
</head>
<body>
<h2>File Store Service - Upload Template Example</h2>
<form>
<fieldset>
<legend>Inputs</legend>
<div>
<label for="template">Template:</label>
<input id="template" type="file" required>
</div>
</fieldset>
<fieldset>
<legend>Options</legend>
<div>
<input id="named" type="checkbox" checked>
</div>
<div>
</div>
</fieldset>
<fieldset>
<legend>Actions</legend>
<div>
</div>
</fieldset>
</form>
</body>
</html>
JavaScript/jQuery
/* File Store Service - Upload Template Example */
(function ($, c) {
"use strict";
$(function () {
c.setupExample();
c.setupTemplateFileInput($("#template"));
event.preventDefault();
var file = $("#template")[0].files[0],
named = $("#named").prop("checked"),
persistent = $("#persistent").prop("checked");
var settings = {
type: "POST",
url: "/rest/serverengine/filestore/template?persistent=" + persistent,
data: file,
processData: false,
contentType: "application/zip"
if (named) settings.url += "&filename=" + file.name;
$.ajax(settings)
.done(function (response) {
c.displayInfo("Template '" + file.name + "' Uploaded Successfully");
c.displayResult("Managed File ID", response);
}(jQuery, Common));
Screenshot & Output
Usage
To run the example simply select the Browse button and then select the template you wish to upload using the selection dialog box.
Next you can specify the following options to use with the upload of the template:
- Named – allow this template to be identified/referenced by its Managed File Name as well as its Managed File ID
- Persistent – make this template persistent in the file store
Note: Only one Managed File in the file store can be associated with a specific name. If two files are uploaded to the file store under the same name, then only the most recently uploaded file will be associated with (or can be referenced using) that name.
Once the template and options are selected, simply select the Submit button to upload the template to the server's file store and the resulting Managed File ID for the template will be returned and displayed to the Results area.
Discussion
When our event handler function is called, we then obtain a reference to the local template previously selected. This is achieved by getting the first value of the files
attribute of the HTML element with the ID of template
(in this case a file type input HTML element) and storing it in a variable file
We also obtain boolean values for the Named and Persistent options (both checkbox type input HTML elements) and store them in the named
and persistent
variables respectively.
Next we construct a jQuery AJAX request which will be sent to the File Store REST service. We use an object called settings
to hold the arguments for our request:
Method type
and url
arguments are specified as shown earlier, with the addition of a persistent
query parameter which specifies whether the template is to be persistent in the file store when uploaded.
We specify the variable file
as the data
or contents of the request, a contentType
argument of "application/zip"
, and because we are sending file data we also specify a processData
argument set to false
If the Named option is checked in our form, and the named
variable is true
, then a filename
query parameter is also added which contains the file name of the template selected (file.name
Lastly, the settings
object is passed as an argument to the jQuery AJAX function ajax
and the request is executed.
When the request is successful or done, a request response is received and the content of that response is passed as the function parameter response
. In the example, we then display the value of this parameter which should be the new Managed File ID of the template in the File Store.
Further Reading
