Creating Content for Web By Data Record
Problem
You want to create and retrieve web content using a template and an existing Data Record as inputs.
Solution
The solution is to create a request using the following URI and method type and submit it to the server via the Content Creation (HTML) REST service:
Process Content Creation (By Data Record) | /rest/serverengine/workflow/contentcreation/html/{templateId}/{dataRecordId: [0-9]+} | GET |
Example
HTML5
cch-process-by-dre.html
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<title>Process Content Creation (By Data Record) Example</title>
<script src="js/cch-process-by-dre.js"></script>
</head>
<body>
<h2>Content Creation (HTML) Service - Process Content Creation (By Data Record) Example</h2>
<form>
<fieldset>
<legend>Inputs</legend>
<div>
<label for="datarecord">Data Record ID:</label>
<input id="datarecord" type="text" placeholder="1234" required>
</div>
<div>
</div>
</fieldset>
<fieldset>
<legend>HTML Parameters</legend>
<div>
</div>
<div>
<label for="inline">Inline Mode:</label>
<select id="inline">
<option value="NONE">None</option>
<option value="CSS">CSS</option>
<option value="ALL">All</option>
</select>
</div>
<div>
<label for="cssSelector">CSS Selector:</label>
<input id="cssSelector" type="text" placeholder="CSS Selector">
</div>
</fieldset>
<fieldset>
<legend>Actions</legend>
<div>
</div>
</fieldset>
</form>
</body>
</html>
JavaScript/jQuery
/* Content Creation (HTML) Service - Process Content Creation (By Data Record) Example */
(function ($, c) {
"use strict";
$(function () {
c.setupExample();
event.preventDefault();
var dataRecordId = $("#datarecord").val(),
templateId = $("#template").val(),
section = $("#section").val().trim(),
cssSelector = $("#cssSelector").val().trim(),
params = {
inline: $("#inline").val()
if (section.length) params.section = section;
if (cssSelector.length) params.cssSelector = cssSelector;
/* Process Content Creation (By Data Record) */
$.ajax({
type: "GET",
url: "/rest/serverengine/workflow/contentcreation/html/" +
templateId + "/" + dataRecordId,
data: params,
dataType: "file"
c.displayResult("Result", c.dataToFileLink(response, "Output"), false);
}(jQuery, Common));
Screenshot & Output
Usage
To run the example you first need to enter your Data Record ID and the Template Managed File ID/Name (previously uploaded to the file store) into the appropriate text fields as your inputs.
Next you can specify the HTML parameters to use when creating the web content:
Section – the section within the Web context of the template to use
Inline Mode – the inline mode to be used in the creation of content
CSS Selector – a CSS selector for the creation of only a specific HTML element within the template
Lastly, select the Submit button to create and retrieve the web content. When the response returns a Result Link will be displayed in the Results area. This link can be selected to view the resulting web content that was created.
Further Reading
See the Content Creation (HTML) Service page of the REST API Reference section for further detail.
