Get Result of Operation
Retrieves the final result of a completed All-In-One operation of a specific operation ID.
Request takes no content, and on success returns a response (depending on the All-In-One configuration) containing either:
  • the ID of the Data Set, Content Set or Job Set entity produced, or
  • the absolute paths of the final output files produced (multiple spool files) or the content of a final output file (single spool file).
Request
Method Type:
POST
URI:
/rest/serverengine/workflow/print/getResult/{operationId}
Content:
Content Type:
Add. Headers:
Parameters
Path
operationId
Operation ID of All-In-One operation
Response
Success
200
OK
Either:
  • ID of the Data Set, Content Set or Job Set, or
  • Absolute Paths of the Output Files or the Output File itself
application/octet-stream
If the returnIdInHeader parameter in the JSON All-In-One Configuration is set to true, the response contains the following additional headers:
  • X-Data-Set-ID
  • X-Content-Set-ID
  • X-Job-Set-ID
  • X-Result-Type
Result of completed operation successfully retrieved
The "X-Result-Type" header could have one of the following values:
  • "Data-Set-ID" - the entity contains a dataSetID (only data mapping operation requested)
  • "Content-Set-ID” - the entity contains a contentSetID (last operation: content creation)
  • "Job-Set-ID" - the entity contains a jobSetID (last operation: content creation)
  • "Output-Streamed" - the entity contains a streamed output file (last operation: content creation)
  • "Output-Local-Filepath" - the entity contains absolute path of output file (last operation: content creation)
  • "Output-Managed-Info" - the entity contains ID of persisted output file(s) (last operation: content creation)
Error
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
404 Not Found
application/json
Operation not found in Server
