Process All-In-One (Adhoc Data)
Submits a request to initiate a new All-In-One operation using pre-existing inputs, with the exception of input data, which is submitting along with the request.
Request takes binary file data as content, and on success will return one of two responses depending on the type of operation:
  • Asynchronous – response containing additional headers that specify the ID of the new operation as well as link URLs that can be used to retrieve further information/cancel the operation (Default)
  • Synchronous – response (depending on the parameters specified) containing either:
    • the absolute paths of the final output files produced (multiple spool files) or the content of a final output file (single spool file)
    • the absolute path or paths of the final output file or files produced (single or multiple spool files respectively) (Get Result as Text Only)
Request
Method Type:
POST
URI:
/rest/serverengine/workflow/print/{dmConfigId}/{templateId}/{jcConfigId}/{ocConfigId}
Content: Data File (File)
Content Type:
application/octet-stream
Add. Headers:
Parameters
Path
dmConfigId
The Managed File ID (or Name) of the Data Mapping configuration in File Store
templateId
The Managed File ID (or Name) of the template in File Store
jcConfigId
Optional – the value of "0" can be specified if no preset is to be used
The Managed File ID (or Name) of the Job Creation Preset in File Store
ocConfigId
The Managed File ID (or Name) of the Output Creation Preset in File Store
Query
async
true
Whether to run the operation asynchronously
resultAsTxt
false
  • Whether to retrieve the result as text (Synchronous Only)
  • createOnly
    false
    Whether output is to be only created in the server and not sent to it's final destination
    printRange
    A specific range of records in the input data file to restrict the print output to
    filename
    The file name of the data file to be uploaded
    Response
    Success
    202
    Accepted
    • operationId – Operation ID of new All-In-One operation
    Data file successfully uploaded to File Store and creation of new operation successful
    Success (Synchronous)
    200
    OK
    Absolute Paths of the Output Files or the Output File itself application/octet-stream Data file uploaded to File Store and a new operation was created and completed successfully with the result returned
    Success (Synchronous + Get Result as Text)
    200
    OK
    Absolute Path(s) of the Output File(s) text/plain Data file uploaded to File Store and a new operation was created and completed successfully with the result returned
    Error
    400 Bad Request
    application/json
    Unable to locate one or more inputs in File Store with Managed File ID(s) and/or Name(s) specified
    401 Unauthorized
    application/json
    Response when either:
    403 Forbidden
    application/json
    500 Internal Server Error
    application/json
    General error with running the All-In-One Process or a specific error relating to the uploading of the data file or an individual workflow process (see error description)
