Cancel an Operation
Requests the cancellation of a running Content Creation (Email) operation of a specific operation ID.
Request takes no content, and on success returns a response with no content.
Request
Method Type: |
POST |
URI: |
/rest/serverengine/workflow/contentcreation/email/cancel/{operationId} |
Content: | – |
Content Type: |
Add. Headers: |
Parameters
Path parameters
operationId |
Operation ID of Content Creation (Email) operation |
Response
Success
204 No Content |
Operation cancellation requested |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
404 Not Found |
application/json |
Operation not found in Server |
