Get Result of Operation
Retrieves the final result of a completed Content Creation (Email) operation of a specific operation ID.
Request takes no content, and on success returns a response containing a JSON Email Output List of all the email output messages created in the File Store.
Alternatively, if the operation was to create email output directly to a SMTP mail server, then a response containing a report on the number of emails that were successfully sent will be returned instead.
Request
Method Type:
POST
URI:
/rest/serverengine/workflow/contentcreation/email/getResult/{operationId}
Content:
Content Type:
Add. Headers:
Parameters
Path
operationId
Operation ID of Content Creation (Email) operation
Response
Success
200
OK
JSON Email Output List of the email message output in File Store
text/plain
Result of completed operation successfully retrieved
Response when the email parameters specified in the original request that created the operation does not contain a host value specifying the network address or name of a SMTP mail server
200
OK
Result of Content Creation (Email) Operation (with successful email count) (e.g. "3 of 3 emails sent")
text/plain
Response when the email parameters specified in the original request that created the operation contained a host value specifying the network address or name of a SMTP mail server
Error
400
Bad Request
application/json
Context not found / Section not found
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
404 Not Found
application/json
Operation not found in Server
