Process Content Creation (By Data) (JSON)
Submits a request to initiate a new Content Creation (Email) operation.
Request takes a JSON Record Data List (with Email Parameters) of the data values for one or more Data Records as content, and on success returns a response containing additional headers that specify the ID of the new operation as well as link URLs that can be used to retrieve further information/cancel the operation.
Request
Method Type:
POST
URI:
/rest/serverengine/workflow/contentcreation/email/{templateId}
Content: JSON Record Data List (with Email Parameters) specifying a list of data values for the Data Record(s) and parameters to be used for content creation
Content Type:
application/json
Add. Headers:
Parameters
Path
templateId
  • The Managed File ID (or Name) of the template in File Store
  • Query
    section
    Default section in template
    The Section of the Email context to export
    Response
    Success
    202
    Accepted
    • operationId – Operation ID of new Content Creation (Email) operation
    Error
    401 Unauthorized
    application/json
    Response when either:
    403 Forbidden
    application/json
    404 Not Found
    application/json
  • Template not found in File Store
