Process Content Creation (By Data Set ID) (JSON)
Submits a request to initiate a new Content Creation (Email) operation.
Request takes a JSON Email Parameters (with Runtime Parameters) object or a JSON Parameters object describing a list of runtime parameters., and on success returns a response containing additional headers that specify the ID of the new operation as well as link URLs that can be used to retrieve further information/cancel the operation.
Request
Method Type:
POST
URI:
/rest/serverengine/workflow/contentcreation/email/{templateId}/{dataSetId}
Content: A JSON Email Parameters (with Runtime Parameters) object, or a JSON Parameters object describing a list of runtime parameters.
Content Type:
application/json
Add. Headers:
Parameters
Path
templateId
  • The Managed File ID (or Name) of the template in the File Store
  • dataSetId
    The Data Set ID which was the result of a data mapping operation.
    Query
    section
    Default section in template
    The section of the Email context to export.
    Response
    Success
    202
    Accepted
    • operationId – Operation ID of new Content Creation (Email) operation
    Error
    401 Unauthorized
    application/json
    Response when either:
    403 Forbidden
    application/json
    404 Not Found
    application/json
  • Template not found in File Store
