Create Preview Image (By Data) (JSON)
Submits a request to create a preview image of the print, email, or web output for a single data record.
Request takes a JSON Record Data List (with Image Parameters) of the data values for the Data Record as content, and on success returns a response containing the image output produced, specific to the record data and parameters specified.
Request
Method Type: |
POST |
URI: |
/rest/serverengine/workflow/contentcreation/imagepreview/{templateId} |
Content: | JSON Record Data List (with Image Parameters) of the data values for the Data Record |
Content Type: |
application/json |
Add. Headers: |
Parameters
Path Parameters
templateId |
Yes |
String |
The Managed File ID (or Name) of the template in File Store |
Response
Success
200 OK |
Preview Image |
image/jpeg |
Creation of a preview image successful. Response when the image parameters specified contain:
200 OK |
Preview Image |
image/png |
200 OK |
Preview Images (Zipped) |
application/zip |
Creation of preview images successful. Response when the image parameters specified contain:
Error
400 |
application/json |
Context not found / Section not found |
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
404 Not Found |
application/json |
Template not found in File Store |
