Get Managed Result of Operation
Retrieves the Managed File ID of the final result of a completed Output Creation operation of a specific operation ID.
Request takes no content, and on success returns the Managed File ID of the output (file or directory) in the File Store.
Request
Method Type:
POST
URI:
/rest/serverengine/workflow/outputcreation/getManagedResult/{operationId}
Content:
Content Type:
Add. Headers:
Parameters
Path
operationId
Operation ID of Content Creation operation
Response
Success
200
OK
text/plain Result of completed operation successfully retrieved
Error
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
404 Not Found
application/json
Operation not found in Server
