Process Content Creation (By Data Set)
Submits a request to initiate a new Content Creation operation.
Request takes a JSON Parameters object, and on success returns a response containing additional headers that specify the ID of the new operation as well as link URLs that can be used to retrieve further information/cancel the operation.
Request
Method Type: |
POST |
URI: |
/rest/serverengine/workflow/contentcreation/{templateId}/{dataSetId} |
Content: |
A JSON Parameters object describing a list of runtime parameters. |
Content Type: |
application/json |
Add. Headers: |
Parameters
Path
templateId |
The Managed File ID (or Name) of the template in File Store |
dataSetId |
The ID of the Data Set entity in Server |
Response
Success
202 Accepted |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
404 Not Found |
application/json |
Template or Data Set entity not found in File Store/Server |
