Get Content Item Properties
Returns a list of the properties for a specific Content Item entity.
Request takes no content, and on success returns a response containing a JSON Name/Value List (Properties Only) of all the properties for the Content Item.
Request
Method Type: |
GET |
URI: |
/rest/serverengine/entity/contentitems/{contentItemId}/properties |
Content: | – |
Content Type: |
Add. Headers: |
Parameters
Path
contentItemId |
ID of the Content Item entity in Server |
Response
Success
200 OK |
JSON Name/Value List (Properties Only) of properties for Content Item | application/json | – | Content Item entity properties successfully retrieved |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
