Get Data Record for Content Item
Returns the ID of the corresponding Data Record for a specific Content Item entity.
Request takes no content, and on success returns a response containing a JSON Data Record Identifier for the Data Record of the Content Item.
Request
Method Type: |
GET |
URI: |
/rest/serverengine/entity/contentitems/{contentItemId}/datarecord |
Content: | – |
Content Type: |
Add. Headers: |
Parameters
Path
contentItemId |
ID of the Content Item entity in Server |
Response
Success
200 OK |
JSON Data Record Identifier for the Data Record of Content Item | application/json | – | Data Record Identifier returned |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
