Rasterize File
Converts a PDF, PS, AFP or PCL file into a bitmap. The conversion can be done for a single page or for multiple pages.
Request takes JSON Bitmap Parameters JSON Bitmap Parameters as content, and on success returns the converted page as a PNG or JPEG file, or returns a ZIP file with the converted images (PNG/JPEG) if rasterization is requested for more than one page.
Request
Method Type:
POST
URI:
/rest/serverengine /workflow/rasterize/{dataFileID}
Content: JSON Bitmap Parameters
Content Type:
application/json
Add. Headers:
Parameters
Path
dataFileId
Yes Number
The Managed File ID (or Name) of a PDF, PS, AFP or PCL file in the File Store
Response
Success
200
OK
A stream with a JPEG/PNG image or a ZIP file with JPEG/PNG images application/zip, image/jpeg, or image/png   Bitmap creation successful
Error
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
404 Not Found
application/json
ID of uploaded PDF, PS, PCL, or AFP data file cannot be found in filestore
