Create Content Set
Submits a request to initiate a new Data Mapping operation.
The Data Mapping operation generates a Data Set, based on the provided data mapping configuration and PDF/PS/AFP/PCL data file, and a Content Set based on the Data Set.
The data file is consumed according to the data mapping configuration. The resulting data records are then used as background in Content Items. The Content Items are created without a template.
Request takes a JSON Identifier (for Content Creation), and on success returns a response containing additional headers that specify the ID of the new operation as well as link URLs that can be used to retrieve further information/cancel the operation.
Request
Method Type: |
POST |
URI: | /rest/serverengine/workflow/datamining/createcontentset/{dataFileID} |
Content: | JSON Identifier (for Content Creation) |
Content Type: |
application/json |
Add. Headers: |
Parameters
Path
dataFileID |
– | – | – | The ID of the PDF/PS/PCL/AFP data file in the File Store that will be consumed according to the data mapping configuration to create a Content Set. |
Response
Success
202 Accepted |
Error
400 |
application/json |
Data mapping configuration not made for PDF files. |
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
404 Not Found |
application/json |
Data file or data mapping configuration not found in File Store |
