Get Result of Operation
Retrieves the final result of a completed Data Mapping operation of a specific operation ID.
Request takes no content, and on success returns a response containing the ID of the Data Set produced (or Content Set for a PDF/VT to Content Set specific data mapping operation).
Alternatively, if the operation was to only validate the data mapping, then a response containing a JSON Data Mapping Validation Result will be returned instead.
Request
Method Type: |
POST |
URI: |
/rest/serverengine/workflow/datamining/getResult/{operationId} |
Content: | – |
Content Type: |
Add. Headers: |
Parameters
Path
operationId |
Operation ID of Data Mapping operation |
Response
Success
200 OK |
Data Set ID (or Content Set ID) |
text/plain | – | Result of completed operation successfully retrieved |
Success (validate)
200 OK |
JSON Data Mapping Validation Result |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
404 Not Found |
application/json |
Operation not found in Server |
